tiling border
kth10
In general, when there is a situation in the picture, it cannot create the tile border, how can we solve it?
Try to create the tile by changing the trim algorithm of the right end of the beam with the Modify/Object Edit/Object trim method command. If not, add the project. Let's examine if there is a problem in the slab analysis.
There does not appear to be a problem with the slab analysis. A closed area can be created by connecting the K03 beam from the upper left corner of the S01 column.
Mr. Levent, I am getting an error on the basis of this, although I have increased the foundation height and amplitude as much as possible, I still get an error, can I have a deficiency in data entry in the program?
There is an AS error in some parts of your raft, when I increased the additional reinforcements, the problem went away, but there are definitely other solutions. ÖMER FARUK ÇAKIL INS. ENG
