Hello there. You should make a semi-rigid diaphragm solution. You are probably making a full rigid diaphragm solution. In this solution method, the sole task of the floors is to transfer loads to the beams. Therefore, they do not appear in the analysis. This is the solution referred to as "rigid diaphragm" in the literature.
