Tile thickness requirement not met
sara
Hello, in my project, in the D10 and D33 slabs on the attic floor (slabs on the left), slab thickness = 16 cm and it does not improve even though I increase the amount of reinforcement and put flat reinforcement at the bottom + top, what else can I do? I'm very tired, sorry, have a good work
"sara":3h9b7l7o" said:
Hi, in my project, slab thickness=16 cm was selected in the D10 and D33 slabs (slabs on the left) in the attic, and although I increased the amount of reinforcement and put flat reinforcement at the bottom + top, it does not improve, what else can I do? I need this problem, thanks in advance for your help, I've been tiring you out for 2 days, I'm sorry, good work
Hello, there is a minimum thickness problem in D10 and D33 slabs. This problem cannot be solved by increasing the reinforcement. In the Slab Thickness control report, it is seen that the minimum thickness should be 16.3 and 16.4 cm. Good work
Thank you very much, Mr. Levent, I was wondering if there is a solution other than that, but I think there is no solution
