friends I am encountering such an error while defining tiling beams beware of circular node points Although I tried, I could not figure out what caused it, can you help?
Hello, If you look at the beam located on the upper edge of the slab, connect that beam to the upper right corner of the S8 column, which has been entered into the S8 column. You will then be able to create the tile in the view you want. Also, I suggest that you enter the curtains you define as columns and model them as shells.
