Re: Steel reports Hello; In fact, if you examine the section effects, there is axial load on all beams and braces, but the report is written as a warning. We can't get this situation when we create a new model. For this reason, I ask you to close the program, open the program again while holding down ctrl + shift. A cache cleared warning will appear in front of you. Then re-enter the similar project. But during model entry, first create the 2 columns and beams. Build the beam straight, make the cantilever outputs, then adjust the curvature. Enter and edit the last crosses. At this stage, you do not need to enter any combination, analyze once, get an optional report and check if there is a warning. Then continue with the other modeling steps. You can check it by doing similar operations in the attached project. Good work.
