There is a difference in column reinforcement expansion
memox85
In the new version, there is a process that I do not understand in the vertical expansion of the columns, the shoots coming out of the foundation are long and the column shoots are tied from the top. I would appreciate if you could give the same information about the situation on the upper floors.
"memox85":1vf02xk8" said:
In the new version, there is a process that I don't understand in column vertical expansions, the shoots coming out of the foundation are long and the column shoots are tied from the top.
Thanks for information. But good luck to the chief who can make the master do this application. It takes skill to connect the column in the air. It would be easier if they made a mason system.
