THERE ARE UNSUITABLE OBJECTS !!!
efsane
I have 120 cm long 30x60 beams in my project. It says there are inappropriate objects and it can't fix the compressions?
In short beams, as the size increases, the moment of inertia increases and the section appears insufficient, the solution is to reduce the dimensions of the short beam and increase the diameter of the stirrup and the number of stirrups of the beam to meet the shear force,
Unsuitable objects are exposed according to the loads, frame selection, regulation conditions and will vary according to the conditions in your project. In short, it is a situation that changes from project to project. For a clearer answer for the purpose, the project needs to be examined.
