The system cannot be resolved
Apokalips
Good afternoon, the system cannot be solved in the project I have stated in the attachment, do a geometric check. warning warning, but there is no error in the geometric control. Can you give your opinions and suggestions about the problem?
Hello, The problem -The system cannot be solved- is due to the inability to create a mesh on eaves in the solution according to the semi-rigid diaphragm assumption. (D23-24-25-26 etc.) At this stage, I will suggest you to make a solution based on the assumption of a fully rigid diaphragm. Good work
Hello. If you remove the ground floor D10 and basement floor D6 slabs and remove the board floor rigidity, it gives an error-free result. Unver ÖZCAN
"unver":20rgsgvz" said:
Hi, if you remove the ground floor D10 and basement floor D6 slabs, and if you remove the basement floor rigidity and make the calculation, it gives an error-free result. Ünver ÖZCAN
Thank you. Later on, we will arrange those slabs in the formwork plan ourselves, right? ?
