The raft is not recovering the base and I can't untie the staples.
friends, the foundation does not save even though I made 1.5m, it does not save no matter how much I open it to the sides. it gives an error of lack of basic reinforcement, there is no problem in strength, but it gives an error of lack of reinforcement, can you please help.
"Hüseyin Yalçın":29er2j45" said:
friends, it doesn't save the foundation even though I make 1.5m, it doesn't save no matter how much I open it to the sides. it gives an error of insufficient basic reinforcement. There is no problem in strength, but it gives an error of reinforcement insufficiency, can you please help.
Insufficient reinforcement in raft foundation Increasing the thickness may not provide the desired contribution to the solution of the problem. You can solve the problem by selecting larger reinforcement diameters from the reinforcement selection dialog. In the Raft Reinforced Concrete dialog, examine the "Moment -Reinforcement areas" and "additional reinforcements" tabs for each reinforcement axis to detect the deficiency and select the raft reinforcement selection dialog. Reinforcement diameters can be increased to meet the need. -To overcome the problem of stapling on raft foundation; The thickness of the raft flooring can be increased. If the punching problem is in the outer columns and there is no amplification, ampation can be made. Concrete class can be increased. Column/wall size can be increased. Column- Curtain Properties/Punching Reinforcements tab Punching reinforcement can be used in the process... (The drawings of the selected punching reinforcement are not made automatically. You have to do it yourself by reviewing the raft punching report and using the 2D possibilities) Good work
