THE PROGRAM IS CLOSING ITSELF
btemel52
ADD'm FILE IMPORT IS AN ARCHITECTURAL PROJECT ON NORMAL KOLN AXLE BEAM ENTRY DONE WELL FINE HOLLOW SYSTEM GİRERKENH is what wisdom K196 and K194 BEAM CONSOLE the UP to EXTERIOR WALLS handing PROGRAM SELF CLOSE SEVERAL TIMES TRIED if I SAME ERROR DOING ACABA WHERE ERRORS DO I CONSOLIDATED END of you SEE ID FILE IN A BIND 25/32 BEAMS DO NOT FULLY INTERCESS WITH THE MAIN BEAM CONSOLES. ALSO, USING THIS ARCHITECTURAL IMPORT AS A REFERENCE, WE DON'T MAKE ANY MISTAKES BY ENTERING IN THREE-DIMENSIONALS, I SHOULD HELP ME WITH THESE PROBLEMS, THANKS IN ADVANCE
Hello there; The primary problem in your project is that your axis intersections do not intersect with the points where your columns are defined (due to the fact that the columns are not fully defined to the axes in the architectural project you use as a base). For this reason, column-beam connections cannot be formed properly when defining beams. As for the 25/32 beams at the console ends, the program does not allow you to define the carrier beams in such a way that they will be divided at intervals smaller than 25 cm, so there is a connection problem. In some console floors, problems occur because the floor edge and the beams are drawn on top of each other. Advice; It is useful to enter everything from scratch in projects where there is a possibility of incorrect definitions in this type of architecture. I wish you good work...
