The program gives a low error of stepped building beam reinforcement.
mustafaureyen
EASY TO EVERYONE. MY MODEL FOR A TWO-STAGE BUILDING IS IN THE LINK. EVEN BY BEAM REINFORCEMENT AREAS LOOKING SUFFICIENT, BEAM REINFORCEMENT GIVES A LOW ERROR. THANK YOU FOR YOUR COMMENTS.
Re: STAGED BUILDING BEAM REINFORCEMENT LOW ERROR Hello, enter the interval value for the stirrup tightening zone on the left support. If you edit the beam stirrup as fi8/20, fi8/20/9, the missingAs message will disappear.
Thank you, Mr. Hakan. There is also a stapling error in the column, but that column continues down. I draw a raft edge from the column border and the raft base defines the bottom of the column.
"mustafaureyen":1ssr6kg9" said:
Thank you, Mr. Hakan. There is also a stapling error in the column, but that column continues down. I draw a raft edge from the column border and it defines the raft foundation under the column.
Hello Mr. Mustafa, on the ground floor of the S18 column If you want no stapling check, define the raft edges 1-2 cm from the inside of the column Note: The size of the S18 column looks 35/60 on the ground floor and 35/70 on the upper floors.
