The program closes while importing the mold plan
prjm
Good evening, I am trying to extract the drawings after analyzing the project, but the program closes by itself while drawing out the floor formwork plan.
Re: FLOOR MOLD PLAN
Hello, In the project you added, the floor formwork plan closes.[/quote] There is a problem while dwg exprt the floor formwork plan. The reason is that the floor boundaries on the ground floor and the related flooring reinforcement drawings are formed incorrectly. In the attached example, the ground floor slabs were redefined and the formwork plan was taken. The dwg export process can be performed without any problems. Note: At -300 level on the ground floor Laying is defined on the basement walls. If you want the basement walls to be shown on the formwork plan, uncheck the basement option from the wall properties and get the formwork plan. Cassette tooth spacing does not meet the condition given in TS500 11.3.2.
Good work
Re: Pattern plan hello easy. when buying a mold plan; I choose my colors in general settings - colors. but it does not use the color I want when drawing. What is the reason? can you help me? for example : I choose the axle color pink , but it comes out in gray .
Hello, The color and pen thickness settings of the objects appearing in the mold plans are prepared based on the colors selected in the settings of the relevant object. If you want to change the color of the axis lines from the mold plans, you can get your drawings by editing the color of the lines in the object properties to pink. Good work.
"Emrah YILDIZ":31n53wgv" said:
Hi, Color and pen thickness settings of the objects appearing in the pattern plans are prepared based on the colors selected in the settings of the relevant object. you can get your drawings. Good work.
thank you very much
