The problem of not getting Static reports in the latest version
huseyinakkus56
Hello.. I just downloaded the new version. After clicking "Create report", the report does not open. (Likewise, Quantity is not received) Apart from these; - Raft top and bottom reinforcements were spaced 20 cm apart. Generally, there was a gap of 10 to 12 cm in buildings of this height. I wonder if I made a mistake somewhere while defining the raft? - Where we pass the raft reinforcement axis, the reinforcement changes accordingly, how can we understand this other than the trial-and-error method? For example: While the reinforcements are placed 20 cm apart, I want to pass them from a place where I can throw them 13-15 cm apart, how can I see this? (I can adjust the reinforcement as I want in the analysis-raft foundation part, but I want to get rid of some additions if possible by changing the location of the reinforcement axis) - It also does not provide stapling security. Especially on my 2nd radium, there are 4 layers, is it normal that stapling does not provide security? - Apart from these, if you have any suggestions about the project, I would like to listen. Link:
Hello
"huseyinakkus56":o90uxo79" said:
I just downloaded the new version. After clicking "Create report", the report does not open. (Likewise, the Quantity is not received)
I have made an account. There is no problem in getting the report, (Your computer If it's an old model, you may have to wait for a report.)
I wonder if I made a mistake while defining the raft?
The definition is ok,
- It also does not provide stapling security Especially on my 2nd raft, there are 4 floors. Is it normal that the stapling security does not provide?
Normal, column moments are taken into account, you can put punching reinforcement in non-recoverable columns, --Do not solve the two structures together, (you have separated the foundation) separately, --Rx , Untick the 2nd basement floor, --Make a semi-rigid solution, --Make the curtains grouped, --Mark the basement curtains as basement curtains, --Take HY 0.5 t/m2 on the balconies, -It can reduce the floor loads on the 9th floor wall you can remove their load, Unv private OZCAN
"huseyinakkus56":2eb0wyhd" said:
Hi.. I just downloaded the new version. After clicking "Create report", the report does not open. If you can't get it, follow the steps below in order. 1-Close the İdeCAD Static program. 2-Disable any antivirus software. 3-Check whether the "Microsoft Visual C++ 2015-2019 Redistributable (*86)" plug-in is installed in the Add/Remove Programs section. or download and install from the link below:
To solve the punching problem, it can increase the raft blood strength, higher strength concrete
- Apart from these, if you have any suggestions about the project, I would like to listen.[ /quote] In your project, the 2nd basement is rigid in one direction. According to TBDY 2018 article 3.3.1.1, the entire floor can be considered rigid or not rigid. It would be appropriate to solve the dilations in separate project files. It would be appropriate to define curtains P03-P11 as group curtains. You can define the P11 pitch as a short head pitch since 1/6 ratio is not provided. In addition, the P11 screen is defined in size 30/165 in the 1st and .2 basement floors, while it is defined in size 30/85 in the ground floor and a column is entered at the end. It is defined as 30/165 again on the upper floor. 1st and 2nd . the basement floor is not rigid. It would be appropriate to mark the basement perimeter curtains as "basement/curtain that does not continue to the upper floor". Good work
Mr. Levent, I tried what you said 2 times in order, it still won't open. The report seems to be fully opened, and it closes. The pc is not old, I was working on this project yesterday, there was no problem, it happened after the update.
"huseyinakkus56":2lrpigxe" said:
Levent Bey, I tried what you said 2 times in order, and it still won't open. The report seems to open and closes. The PC is not old either. I was working on this project yesterday, there was no problem, it happened after the update.
By the way, I did the installation while the anti-virus was on, let me do the installation again by disabling the anti-virus.
Thank you Unver and Levent for your suggestions. I ran into this problem because I did the installation with anti-virus enabled. I reinstalled it now and it's fixed. Thank you for your other suggestions.
