The problem of cutting the elevator perimeter on the U curtain
TheBEaST
It is a problem that I constantly experience.. I experience curtain cutting safety in almost every project in the middle curtain of the curtains (between the 2 curtains) around the elevator. I can find a solution by increasing the curtain thickness, but in this project, there is such a value that it seems impossible to fix it by increasing the curtain thickness. I wonder if there is a problem with the project data, I would appreciate it if you could help me. Also, although I saved it as cde, it was larger than 4MB and I had to use a helper site
Re: THE PROBLEM OF CUTTING THE ELEVATOR CIRCLE ON THE U CURTAIN Hello My Suggestions, --Do not give K23-K24 separately, give it as a single beam from column to column, --Let the column narrow sides be 30 cm -- Solve the staircase together with the building, --Reduce the floor loads in the attic, remove the walls, --The elevator machine must have a floor on which it sits, --The curtains are low, you need to add curtains, when you put a curtain around the elevator (probably), it may be sufficient in the earthquake zone of 4 degrees, but it may not be enough in the earthquake zone of 1 degree. --If the screen ratio is close to 1% of the floor area in one direction (practically), you can balance it without much effort. Take it easy Unver ÖZCAN
