The problem of analysis of the staircase together with the structure
TheBEaST
Hello.. I want to analyze the ladder together with the structure, I watched the sample video. After drawing the reinforced concrete calculation axles, I set the support conditions and then press the analysis button. Even though I didn't say yes to the solution option with the structure, the report and drawing of the stairs were blank as a result of the analysis. but if I press the stair analysis button, the program calculates the stair report and its reinforcements, but this time it does not transfer the stair loads to the building. Is there something I'm missing? can you help me?
"TheBEaST":38wrfvqn" said:
Hi.. I want to analyze the staircase together with the structure, I watched the sample video. After drawing the reinforced concrete calculation axes, I set the support conditions, and then I press the analysis button, even though I said yes to the solution option with the structure, the report of the staircase as a result of the analysis and the drawing is blank. But if I press the stair analysis button, the program calculates the stair report and its reinforcements, but this time the stair loads are not transferred to the building. Is there something I am missing, can you help?
Hello, It is correct to analyze the stair. Do it as a diaphragm.Look at the deformation of the structure, if the ladder moves with the structure as expected, it means that you have solved the structure and the ladder together.The loads to the structure are the extreme forces given in the ladder finite elements.
Do you have a sample at hand? I couldn't set it up, is it just me, or my other engineer friends might be living, a sample made or a more detailed video would help.
"TheBEaST":3cjaaozr" said:
do you have a sample? I am including as an example a part of a project that has actually been implemented so that it can be seen to be supported. The sequence is as follows: 1. Enter the ladder 2. Enter the ladder calculation axes and fixed and live loads 2. Adjust the stair supports together with the structure for solution 3. Semi-rigid structure solve as diaphragm 4. Examine the deformation of the structure 5. Get the ladder drawing and reports.
