hi friends, I had 2 questions. Firstly, when I look at the reports in the project, there is no problem, but when I check the beams, the beam width cannot be more than the beam height and column width, it warns that the columns are 55*55, beams are 100*30 horizontal beams. Do you mind if the width of the single dimension beam I will play with from this point of view, in my 2nd question, cassette slab typical beam definition in cassette slab in geometric control gives an incorrect warning, I do not understand why, I could not add it because the project is large, thanks
