The logic for defining the lower support of the ladder
MustafaAkın20
Hello, we have designed an external staircase to the 2nd floor in a 2-storey project. I defined the upper support as a single side beam-flooring, and the lower support as a fixed support. Other edges are blank. When I make a definition in this way, the relative floor drift increases significantly, including the building stiffness center. A case with the definition of the stair lower support. I define an external continuous foundation under the stairs with a height of +47.5. The center of rigidity approaches the middle and the relative floor drift returns to normal, but when I look at the Z-direction deformation, the ladder does not seem to be supported on the foundation. What solution should I implement? I couldn't figure out the logic of defining the bottom brace of the ladder. Good work.
Re: About Stairs
"MustafaAkın20":3e7pqgpy" said:
Hi, we designed an external staircase to the 2nd floor in a 2-storey project. I defined the upper support as a single side beam-flooring and the lower support as a fixed support. Other edges are free. When I define in this way, the relative floor drift including the building stiffness center increases significantly. It is a situation with the definition of the stair bottom support. I define an external continuous foundation under the stairs with a height of +47.5. The center of rigidity approaches the middle and the relative floor drift returns to normal but when I look at the Z direction deformation, it seems that the staircase is not supported on the foundation. What solution should I apply? I couldn't figure out the logic of defining the lower support of the staircase. Good work.
Hi, the construction behavior when the staircase is resolved together with the structure and its supports are arranged as a fixed support or attached to the structural element It is a normal and expected situation that stair edges are not directly connected to the foundation at the moment. Stair k You can define the basement curtain and the continuous foundation under it as in the example. Good work
