The lines in my imported file are dashed
ozguroz1
Hello everyone, when I import my file that I edited on Autocad, my line showing the beam traces is dashed. Actually, a straight continuous line may not seem like a very important detail, but my project is a bit complicated, so I get confused in some places. Thanks in advance for your help
Hello, Check the properties of line and route objects in your current project. Since the dashed line style is active in the properties of the route and the line, the lines may come in this way when you import them. Try to import the route and line properties again after making them straight lines, or import them after creating an empty project with the Standard template. If the problem persists, send your DWG File and we'll examine it.
