The largest m value is 9.45. In version 7.022... the m value is the impact/capacity ratio. If the effect gets bigger and the capacity gets smaller, it's normal for its value to increase. If your colon is a very forced colon, the colon loses its carrying capacity. In this case, the value can be much larger. However, in your project, as seen in the screenshot above, the largest m value is 9.45 at 7.022. Not as great a value as you mentioned. However, in the first screenshot you added, it is a 4-digit value. A situation specific to the version 8 you are using...
