WE CANNOT MAKE THE COLUMN DIMENSIONS 30/100 DUE TO THE PARCEL BOUNDARY.. OTHER THAN THAT, WE WILL MODEL IT AS YOU SAID..(FLOOR: 15 CM AND SEMI-RIGID DIAPHRAGM. :??..THANK YOU FROM NOW.."unver":1wztlz0g" said:Hello We modeled the staircase correctly (it would be better if the floor thickness was 15cm) and the S11 and S13 columns were 30/100 in size and the structure was semi-rigid diaphragm. Ünver ÖZCAN
."myb63":10d5xj27" said:DUE TO THE PARCEL BORDER, WE CANNOT MAKE THE COLUMN DIMENSIONS TO 30/100..OTHER THAN THAT, WE WILL MODEL IT AS YOU SAID..(FLOOR: 15 CM AND SEMI-RIGID DIAPHRAGM... PROBLEM: PROBLE SIZES OF COLUMN. .THANK YOU IN NOW.."unver":10d5xj27" said:Hello I have modeled the staircase correctly (it better be 15cm slab thickness) S11 and S13 columns I can suggest a solution as 30/100 dimensions and semi-rigid diaphragm structure. Ünver ÖZCAN
"myb63":31n2peeo" said:."myb63":31n2peeo" said:WE CANNOT MAKE THE DIMENSIONS OF THE COLUMNS 30/100 DUE TO THE PARKING BORDER. :15 CM AND SEMI-RIGID DIAPHRAGM..)..Would it be a problem if COLUMN DIMENSIONS STILL LIKE THIS:??..THANK YOU IN NOW.."unver":31n2peeo" said:Hi I have modeled the staircase correctly and (floored) It would be better if it was 15 cm thick) S11 and S13 columns dimensions of 30/100, I can suggest a solution as a semi-rigid diaphragm. Ünver ÖZCAN
