emrah çiçek
The drawings I imported from autocad to ide seem very large, what should I do for this? Is it because of the scale or something else? can you help me?
Based on your previous message, 1 meter = 1 unit scale is used in the program, assuming you are using version 7. After import, scale the drawing so that 1 meter = 1 unit using the "scale" command. Alternatively, do the same with autocad' first. You can also do it and then you can import it in the program Note: In version 8, the scale value can be given during import."emrah flower":3ixlvxx2" said:The drawings I imported from autocad to ide seem too big, what should I do? is it because of the scale or something else? Can you help
You can see its location in the attached picture."emrah Çiçek":1vs8nlpv" said:I couldn't do the scaling, can you help me, I couldn't find the scale command
