The do-it-yourself column connection is not centered.
mustafaureyen
Hello everyone, take it easy, I use the column-column combination (artificial column) macro, if I select the weave type as medium and select the use sheet tab from the parameters, there is no problem. I will be glad if you help, thank you, take it easy.....
hello, I couldn't find the make colon command in the 10.14 version, I would appreciate it if you could help me, the direction of the columns should be changed in your drawing.
Hello there; Column joints with butt plates are under the joint group within the constructive joints. In the long toolbar, it is in its old place. You can also reach the combination by typing an artificial colon into the search bar at the top. Since you are using a cross section, it is not perfectly centered. This situation has been noted to be resolved. Please correct over the drawings in this version. Good work.
