I would appreciate it if you could help me, there are excessive fittings on the curtains.
Log in or register now.
There are no 4 curtains in the project you shared,"oleanders":2dsjp96c" said:I put 4 curtains 250 cm long where I couldn't put them in the last plan, but it was fixed.
TBDY2018 penalizes the structures with hollow blocks, you should return to the column beam system, if you use option 4.9.1.3.b, you should apply the ANNEX 4C details for the infill wall. Example for a hollow block structure: (You have to enlarge the curtains this much to balance it. Not a suitable solution.)"oleanders":2dsjp96c" said:I have no idea where I went wrong.
