Hello, I am designing a raft foundation under the Steel Building. I would place 70 cm high columns on the raft foundation where the base plates will sit. I added the relevant loadings to the G, Q, Ecx, Ecy loading situations in the automatic loading situation. The forces on the column are called "Reinforced Concrete-Column-Forces" In the section named "Reinforcement Areas", I was able to track that the program detects the loads. While all the states in the Automatic reinforced concrete design menu are active, I observed that some of the columns do not use the forces detected in the reinforced concrete design in the reinforced concrete design, and I checked that these forces are not used in the design in the report. (SCREEN SHIPPING HAS BEEN MADE FOR S1 COLUMN.) The relevant static file is attached. I present this situation regarding automatic reinforced concrete design to your valuable comments and wish you good work.
