The beams have no additions. Is flat and assembly enough?
ilhnsrt
i solved the project but i am having problem with beams. The program does not place the top right and bottom right reinforcement across the beams. It puts and passes the mounting reinforcement with flat reinforcement. why does it do this?
Hello
"ilhnsrt":4n5qwry7" said:
The program does not put right upper and lower right reinforcement on the beams.
I understand: You say that the upper right and lower right reinforcement does not add. Existing mounting bars may be sufficient. To say something more clearly You need to add the project Unver ÖZCAN
