I drew the razi polygon in idecad statics, as I did in previous versions, and determined the corner elevations, then I used the "leveling" command to learn the elevations of the points I wanted in the land, but each point came out as 0.00. When I do the same with the idecad architecture, there is no problem. The versions I use are 7.017 64 bit (both architecture, both static)
