f.pehlivan
WHERE CAN WE USE THE BELT BEAM? CAN WE USE K3 AND K4 BEAMERS IN THE PROJECT I ATTACHED.
Tape beam is a constructive element. It is generally not included in the analysis model. The number and diameter of the reinforcement are determined by the user. It is used in tunnel formwork systems to strengthen the free edge of the slab."f.pehlivan":3uoxk2i6" said:WHERE CAN WE USE TAPE BEAMS. CAN WE USE K3 AND K4 BEAMS IN THE APPENDIX PROJECT.
Well, can we not use it in the project I mentioned? Since the beam height cannot be less than 3 times the floor thickness, it can create very bad views in the building."Levent Özpak":254wxc64" said:Band beam is a constructive element. It is not included in the analysis model. The number and diameter of the reinforcement is determined by the user. It is generally used in tunnel formwork systems to strengthen the free edge of the slab."f.pehlivan":254wxc64" said:WHERE CAN WE USE TAPE BELT? CAN WE USE K3 AND K4 BEAMERS IN THE PROJECT I HAVE GIVEN APPENDIX.
"f.pehlivan":2725k7qj" said:It is up to you as it is a constructive element."Levent Özpak":2725k7qj" said:Band beam is a constructive element. It is not included in the analysis model. The number and diameter of reinforcement are determined by the user. It is generally used in tunnel formwork systems to strengthen the free edge of the slab. Since it cannot be less, it can create very bad images in the building."f.pehlivan":2725k7qj" said:WHERE CAN WE USE TAPE BEAMS.
