T.S. 500 madde 11.4.4
yunussacikk
Hello, how can I do this proof? The program throws reinforcements around the shafts, can I do a manual calculation? I would be glad if you help.
If you make a solution taking into account the gaps and discard the provided reinforcements, you will prove it. I think you should do a partial solution.
Hello, - In the Analysis Model window, you can select the Combination "Reinforced Concrete Design Envelope" for the Shell Elements Solved with Shell/Structure component in the Visualization Dialog and check the calculation reinforcement areas (in cm2/m) at the top and bottom for As1 and As2. (You should perform analysis by ticking "Consider earthquake effects in slab analysis" in Analysis Settings.)
