The project is at the link below, I would appreciate it if the related friends could help me..kolya come
Log in or register now.
There is probably a data problem at the node point whose coordinates are written on the screen at level 9.10. O Check the elements at the node."yeni6565":2m4lwkzd" said:project is in the link below, I would appreciate it if the related friends could help with this issue..kolya comeYou do not have permission to view link Log in or register now.
Hello, slab meshes cannot be created because the opening of the D18 console slab is too small. Create the floor on the ground and normal floors with a width of 25 cm in the example. Analysis will be done. Note: -We do not recommend checking the line "Consider the "Nv" contribution of the tie beams that do not meet the 1/3 condition in the calculation of the shear overturning Moment" in the Analysis Settings / TBDY Options tab. Good work."yeni6565":17sc7fuk" said:project is in the link below, I would appreciate it if the related friends help me on this issue..kolya comeYou do not have permission to view link Log in or register now.
