system cannot be resolved error
volkangedik
Modal "CANNOT SOLVE THE SYSTEM ON LOADING" Friends, I couldn't find the problem, I'm waiting for your help, I added the project, thanks in advance...
The problem is at the intersection of K47 and K37 on the L axis; small beam piece is seen... ---------- Note : In such problems, the program writes the problematic joint number and coordinates in the analysis statement. For your information, you can find the solution by following similar problems from there. 0:04 Analysis in progress. 0:04 Performing modal analysis: "Modal". 0:05 ***************************** 0:05 *************** ****** CANNOT SOLVE SYSTEM ON LOADING "Modal".************************* 0:05 Pivot error in matrix reduction. 0:05 Problem joint number : 287 0:05 Node coordinates: X : -1.45 Y : 4.38 Z : 12.30 0:05 ********************* ********** 0:05 The analysis has been cancelled. The solved version of the problem is attached.
