System cannot be resolved error
hydrkrmn
WHEN I MAKE THE REPORT IT GIVES AN ERROR, BUT I CANNOT SOLVE WHY THIS PROBLEM CAUSES MASS AND RIGIDITY CENTER IS IN THE BOTTOM LEFT SECTION OF MY PROJECT, I DON'T UNDERSTAND WHY IT HAPPENS AND I CAN'T SAVE THE RAFT THICKNESS. IS THERE A SYSTEM PROBLEM? THANK YOU IN NOW, IT'S EASY.
"hydrkrmn":2zvto0ja" said:
WHEN I REPORT, IT GIVES AN ERROR, BUT I CANNOT SOLVE WHY THIS PROBLEM IS CAUSED BY THE CENTER OF MASS AND RIGIDITY. GET IT EASY.
Hello. When the analysis is done in the project you added, the center of mass and stiffness can be calculated correctly and a report can be obtained. In the raft floor, there is not a thickness problem, but a lack of reinforcement due to additional reinforcements. Inadequacy problem can be overcome by choosing larger reinforcement diameters from the reinforcement selection dialog. Other Some notes: -Model the panels as shells -Review the errors in the geometry control. -I suggest that you analyze the elevator shaft without leveling the curtains and model the raft foundation as flat, and give the details of the elevator pit separately. Good work
"Levent Özpak":3mvnnmwl" said:
"hydrkrmn":3mvnnmwl" said:
GIVES AN ERROR WHEN I REPORT, BUT I CAN'T SOLVE WHY THIS PROBLEM IS CAUSED. MASS AND RIGIDITY CENTER IS IN THE BOTTOM LEFT SECTION OF MY PROJECT, I DON'T UNDERSTAND WHY IT HAPPENS AND I CAN'T SAVE THE RAFT THICKNESS. IS THERE A SYSTEM PROBLEM? THANK YOU IN NOW, GET IT EASY.
Hello, When the analysis is done in the project you added, the center of mass and stiffness is calculated correctly and a report can be obtained. It is not a thickness problem in raft flooring, it is a lack of reinforcement caused by additional reinforcements. Inadequacy problem can be overcome by selecting larger reinforcement diameters from the reinforcement selection dialog. Some other notes: -Model the panels as shells. -Review the errors in the geometry control. -I suggest that you analyze the elevator shaft without leveling the curtains and modeling the raft foundation as flat, and give the elevator pit detail separately. Good work
-Levent, thank you very much, but when I analyze the system cannot be solved, check the geometry. -We are going this way because the request of the municipalities is like this, but I think to do as you say, actually, thank you for your information on this subject.
"Levent Özpak":2fp6egda" said:
Thank you very much, Levent Teacher, but when I analyze the system can not be solved, check the geometry. ] When I analyzed the 32 bit version of Ver 7.022, it gave me the warning that the system cannot be resolved. There is a small piece of beam on all floors at the junction of the K28-K24 beams. If this piece is deleted, the project can be analyzed. Good work
Thank you Levent Teacher, actually I'm having trouble with this in my idecad, my computer is 32 bit now, let me try to change the computer. Let me delete that beam now, thanks, take it easy
