Supporting conditions in ladder analysis
fatihh.aksy
Hello. There is a staircase in the architecture as I mentioned in the appendix. I drew the part that I showed with the yellow frame, together with the building, as a landing. I drew the remaining 4 digits independently of the structure and will analyze it that way. Before performing the ladder analysis, when determining the support conditions, rotation prevented and translation prevented options should be selected according to what? Thanks.
Re: BACKING CONDITIONS IN THE LADDER ANALYSIS Hello, If the staircase is to be solved independently of the structure; If the edge of the stair is supported on the slab or beam, you can select the "prevented offset" option. If the curtain or column is supported, both options can be ticked.
