If you want to give a report, Report/Structure In this report, you can see the global end forces of all loads at the bottom ends of the column under the heading "Element Results: According to the Elements" or if it is to be viewed as a project, column sub-effects, raw forces, global or column sub-effects in the end forces tab in the column reinforced concrete dialog. You can see it for all downloads in local axes For the meaning of axes:"k0ry":hscqlmbx" said:Greetings, The basic design of the building whose superstructure I solved is out of my scope. I will give the sub-column forces to the friend who will solve the foundation. Where can I find the support reactions. Good work.
