Subasman Plan
AUGURD
I have done my project, I have defined my subbasement curtains, but I cannot get the subbasement plan sheet, unfortunately, can you help me, thank you in advance
Hello, Negative upper elevation value is >60 cm. If you want the basement curtains to be shown in the formwork plan, you can get the formwork plan by unchecking the "curtain that does not continue in the basement/all floors" option in the Curtain properties/static tab. Good work
Thank you for your answer, but I only want to see the patterns in the basic application plan and I want the sub-basement plan as an extra, how can I reach it?
"AUGURD":1vsplzsg" said:
I sent you two sheets, I need to get 2 sheets like this
- Basement plan.pdf is not automatically drawn because it is not a leveling concrete building element.You have to do it yourself using two-dimensional drawing tools. -For drawing in Basic Application Plan.pdf, if you don't want to see the basement curtains, you can get a basic application plan by selecting all other objects except for the basement curtains.
Can't I get the subbasement plan out of nowhere? I have to draw my autocadm myself and hide and remove the subbasement, the result is the same
"AUGURD":38f5q2bs" said:
Can I not extract the basement plan from somewhere? I need to draw my autocadm myself and I save the basement and the result is the same
-Uncheck the "curtain that does not continue in basement/all floors" option in the curtain properties/static tab and after receiving the template plan then you need to edit the drawings for the section and reinforcement representations of the leveling concrete etc. You can change the name of this drawing you have edited to "basement plan".
