Stud Beam
drohendx
Hello, I have 32 cm hollow floor and 32 cm high beams, the size of my lower beam with studs is 4.45m. The length of my middle beam is 5.75m. I am waiting for your comments on how the stud beam to the right of the column I added in the photo affects the rigidity of my building, thank you.
Hi My suggestions --make the outer joists 25/50/ or 25/60, --make the inner joists 50/32. --The narrow sides of the columns should not be less than 30 cm --Make an account, if there is a shortage, you can increase it. Unver ÖZCAN
Ts 500 Distribution teeth should be placed on floors exceeding 4 meters Why stud beam in hollow block floor ? Sent via iPhone using Tapatalk
