stud beam
matrax
Does it add body reinforcement to the 1.ko6 beam and perceive it as a cantilever beam? whereas with k07 it is not a continuous beam? When you lift the k10 beam, can we not load the single load coming from the k10 beam to that point, please explain a little bit about this cone, how does the body reinforcement calculation go. 2. Teacher, when it is a stud beam, should the naming in the figure be split like k06, k07 or should the ko9 beam be a single beam?
The answer to your question is clearly visible in the picture you sent. a stud beam on one side and three beams on the other. Which one do you want, give the answer.
"matrax":20wohrx8" said:
1.ko6 beam is equipped with body reinforcement, does it perceive it as a cantilever beam, but with k07 it is not a continuous beam? When k10 beam is lifted, can we load the single load from the k10 beam to that point, please explain this cone a little bit. What does the hull reinforcement calculation mean
Although the naming of the beams is not important for the analysis, it is important for the second checks. Therefore, instead of naming K06 and K07 separately, name them as one. Since you have given the names K06-K07 for the dividing beam separately, Body reinforcement condition is checked according to the clear span of the beam (TDY article 3.4.1.1)
[2. teacher, should the naming in the figure be split like k06, k07 or should the ko9 beam be a single beam? Thank you..
If you mean to divide by entering as two parts, yes. The first answer I gave for the naming is valid...
1. HOCAM PICTURE 1 (FIG.2) IF I DON'T NAME IT, IF I DON'T NAME K09 BEAM, LIKE K09 BEAM, HOW TO KNOW THE K10 BEAM AT THE POINT, DOES IT MAKE THE CALCULATION OF THE HANGER REINFORCEMENT, CAN I MAKE THE TICKETING? CAN I MAKE A TICKETING AT THE POINT THAT THE K10 BEAM IS CONNECTED? K06,K07 I DID IT AS A SINGLE BEAM ON THE OTHER LIKE K09, THAT IS THE CORRECT APPLICATION K09 OR KO7,KO6. THANK YOU MY TEACHER
"matrax":2k39dw6s" said:
1.HOCAM DOESN'T HAVE THE NAME IN PICTURE 1 (FIGURE 2), LIKE K09 BEAM, CAN THE SUSPENDING ATTACHMENT BE CALLED AT THE POINT AT THE POINT WHERE K10 BEAM KNOWN LIKE THE K10 BEAM? Suspension reinforcement calculation is not made in K06-K07 beams. It can be seen that it is not made in the Beam Suspension Reinforcement Report. Stirrup tightening is done on the left side of K06 and right side of K07. The stirrup tightening region can be seen in the beam details.
I MEAN BY SECTION 2. I DID NAME K06,K07 AS A SINGLE BEAM IN THE OTHER I HAVE ADALNED IT LIKE K09, THAT IS THE CORRECT APPLICATION K09 OR KO7, KO6. THANK YOU MY TEACHER
It is appropriate to give a single name as in K09.
