Hello, the structure shape representation frame on the letterheads is located in the "C:\Program Files\ideCAD\ideCAD Static 8\Annotations) folder. It is located in White 07_YapıŞematikShow.blk for background white color, Black 07_YapıŞematikShow.blk for background black color. After you have drawn your structure diagram at the appropriate size, save it as blk. I mentioned it. Open the White 07_YapıŞematikShow.blk or Black 07_YapıŞematikShow.blk file in the program. Then paste the structure diagram you prepared into the frame. Save the final version somewhere and paste it in the c:\Program Files\ideCAD\ideCAD Static 8\Annotations folder with the same name. Now, every time you receive a drawing, the structure diagram will appear in your drawings. You should do this before you receive the drawings for each project."erdigoksu":2fzld1vc" said:the structure schematic representation on the letterheads is blank, what should we do to draw it
As I wrote in my previous message, you have to draw it for the letterheads."staticçim":326ec2yu" said:Hakan, do we need to draw the structure diagram, so the program doesn't create it by itself?
