There does not appear to be a problem in data entry in general. The performance level of your project is in the collapse zone due to the beams on the ground floor. Reinforcement corrosion and insufficient clamping length multipliers are entered as 0.7 in the beam settings. In the performance analysis options, reinforcement realization coefficients are entered as 0.7. In the light of these data, it can be seen that the moment capacities of beams have decreased considerably. Note: Values such as 12fi12, 21fi12, 13fi12 for mounting, straight and bending reinforcements of the K05 beam are entered. Therefore, the beam is in the position of the brittle element. (The upper left addition of K06 is also more than it should be)
