You cannot perform performance analysis of a non-rigid diaphragm structure with the program. Wrong results come out. The easiest way to evaluate such a structure is the steel roof etc. on it. to perform normal analysis (without rigid diaphragm) by giving the loads from the tops of the columns to join the earthquake mass The end result is to look at the capacity diagrams of the columns. If it does not exceed around 30-40% capacity, there is no problem. Or uploading under performance analysis conditions and performing performance analysis manually. The capacity of the damaged column can be reduced, but since the regulation cannot be used for damaged structures, in any case, it is necessary to jacket the damaged column first and then analyze it.
