Hello, Mr. Hakan, There are some points in the plasform project that I could not add here because it is larger than 2 mb and that I sent you by e-mail, which did not appear when receiving a report, but were given as errors in the geometry control. The beam KB11, located between the elevator curtains, is called unsupported. I couldn't get rid of this error in geometry control even though I placed it over and over again. Similarly, in elevator curtain elements entered as panel element, it tries to control l/b>7 in the curtain definition and gives an error. Again, when I get the beam details of this project and change the font size of the beam detail, I see that this font size change is not made in the additional support reinforcements. The second project in the appendix is an industrial structure. I added the loads coming from the steel shears as point load G, but at one point in the data, there are more than one load that I did not enter. Are these point loads taken into account in the earthquake calculation? By the way, one point I would like to ask is how do you paste pictures on this forum. It doesn't happen with copy paste. Suat Yildirim
