Stiffness in x and y directions in the 2nd basement in floor general settings
omer.faruk
Hello. As seen in the image, there is a curtain on the right and bottom of the 2nd basement floor. not in other parts. In this case, I wonder if I will mark stiffness in the x and y directions in the 2nd basement in the floor general settings?
Re: RIGIDITY PROBLEM Additional information; There is no curtain on the floor called the 1st basement floor. Open on 4 fronts. 3rd basement floor is surrounded by curtains on all 4 sides
Re: RIGIDITY PROBLEM Hello TBDY2018 Article 3.3.1.1.a (a) Rigid basement curtains surround the building from all sides or at least three sides,[/ According to the i] condition: X and Y directions will not be marked on the 2nd basement floor, X and Y directions will be marked on the 3rd basement floor.
"unver":292mzhor" said:
Hello TBDY2018 Article 3.3.1.1.a (a) Rigid basement curtains can protect the building from all sides or at least According to the condition of , the rigidity in the X and Y directions will not be marked on the 2nd basement floor, the rigidity in the X and Y directions will be marked on the 3rd basement floor, Ünver ÖZCAN
Thank you for your response. I do
