stepped raft foundation
tedarmi
A similar topic in the forum was only about the interaction between the gradual raft foundations. After this raft creates the level differences in the foundation, will the difference between the column heights not cause a problem for the carrier system..
"tedarmi":3s25nj3z" said:
similar topic in the forum was only about the interaction between gradual raft foundations. After this raft creates the level differences in the foundation, won't the difference between the column heights cause any problems for the carrier system..
Hello, Screen What problem(s) are you specifically pointing to when you say "problem with the carrier system"?
The short column is the case when the middle region stirrups are not formed in the colon, and TDY conditions are applied automatically in short clones. For short column formation conditions, see the related articles in TDY.
