alpaslanbulut
Hello, I have Half Basement + 6 floors Project, shelter, water tank etc. half basement. Since the project is loaded, I will explain with pictures. +0.15 elevation Basement. -1.00 1st stage raft foundation upper elevation ( 60cm) -2.45 2nd stage raft foundation upper elevation ( 60 cm) My question is; Do I have to define the complete raft and then define the space and define the second raft as described in the forum? Or can I define two different raft edges and create different levels? According to the analysis result; The raft at the -1.00 level gives an As(-) error in the additional reinforcements at the corners in the interior picture (with excessive stress), and most importantly, the marked curtains do not provide cutting safety (I threw the liar in the column but I could cut it locally), I am waiting for your opinions and suggestions on the subject. Respects. Alpaslan
