steel scissors purlins
inansas
Hello there. In my project, I could not define a liner between two scissors that differ in length, I would be glad if you could help me. Also, how can I remove the plate conflicts without making any changes with the scissor dimensions - which I cannot change due to the project. good day, good work.
Re: steel scissors lovers Hello; On the scissors, the purlins are placed only at the nodal points. Therefore, it is not possible to edit with the multi-lover menu. You can produce the purlin system you want using a single purlin. The attached images will help you. Good work.
