civil_kemal
I need to make a 25 meter span steel roof on a reinforced concrete structure. For architectural reasons, I cannot directly attach beams to reinforced concrete columns. I need to model the roof by raising it with a steel column. I modeled the column beam connection as shown in the picture. Do you think this combination is appropriate? Also, when I model the roof alone and model it on a reinforced concrete structure, the joint reports are very different from each other. Which one should I consider? I am sending the data that I modeled as a single steel roof for you to examine
Log in or register now.
