Hi; There were many problems during data entry in the project, for example, connections were entered in fast mode, beam-to-beam connection was formed when there should be a column-beam connection, because your beams on the lower level are 0 to the lower end of the column. The program has connected the ends of columns and beams while creating a joint point, no support has been formed, etc. In order to solve these problems, you can first enter the beams that will be located at the lower level from the perspective screen or from the floor general settings in the plan by creating a floor for that level. Make sure it is 20 cm above. There is a need for a distance in order to make the joints healthy. Turn off the speed mode until you have mastered the program, and enter by first selecting the column and then the beam. When entering the braces, make the type V from the settings and select the beam at the upper end of the column. There was a problem in the analysis model here too .Install one of your partitions in the above-mentioned I arranged according to my You can continue like this. My advice is
 is to get used to the logic of the program by following the videos in the link. Good work.
