I'm trying to learn the İdecad Steel version. As an example, I cannot fix the errors in my project that I modeled. -The pmm ratios of the columns are very large. How can I lower it? How can more economical sections than the sections I use be used in these openings? -Lovers are not passed with upn profile. While modeling the lovers, I defined the tension and defined the cross. When I select UPN, pmm rates are very high. Is there a point I missed? -Is the amount of live load I defined on the composite slab correct? In some of the main beams that I have defined at +12 meters elevation, pmm ratios do not save. How can I solve it? -Can a stability beam be defined to the ridge part on the roof? How ? And also, if you tell me the deficiencies and mistakes you see in the project, I would be pleased. Thank you.
