Hello, You can follow the steps below to change the material properties of steel elements. - Right click on the materials in the build tree and click "Add New Item". Then define your Steel material from the material definition window. -After defining your new material, right click on the section you used in your project in Sections section and enter section properties window. You can select the desired material for the section from the material list.
