Steel Flooring - Steel Roof
mahal
Hello, I messed around with the form a bit, but I had to open a new topic to get the answer I wanted. In some projects, while the column-beam reinforced concrete is made in the intermediate floors, the floor slabs are made on steel beams, and a space frame is also made as the roof. How is this definition made in idestatistics Thanks in advance
This definition is currently unavailable. We know that the ideçelik program is still in the writing phase. The expectation is that there will be a separate program as ideçelik, however; If integration with idestatic and data exchange is provided, the opportunity to use reinforced concrete and steel elements together in a model you mentioned will emerge, and the analysis engine infrastructure that I saw in ide7 is designed to allow for this. When this happens, the slogan of the idea "everything is as planned..." will have its full meaning. hereby, analysis with the assumption of semi-rigid diaphragm that came with idestatic 7 and did not find much resonance, however, which is a great opportunity, a distinctive feature and beauty. We have been learning since our students, that they put their hands under the responsibility, so to speak, on their floors, which are considered infinitely rigid in their plane, by giving their rotations and translations to the frame elements at the nodal points, which do not mix with meat and milk. In other words, in their proud flooring that says I will not bend, bend, deform, become bent and be included in the system analysis. The most realistic construction behavior can thus emerge. In the near future, we will see what this feature, which I see as not in demand for now, is capable of, especially in multi-storey buildings. In my opinion, this feature alone should have created a version on its own, but modestly adapting it to the program, Mr. I would like to express my gratitude to Mr. Ismail and his team. G.KOSE
"mahal":3gl9wmdh" said:
Hi, I tinkered with the form a bit, but I had to open a new topic to get the answer I wanted. In some projects, while the column-beam reinforced concrete is being made in the middle floors, the floor slabs are made on steel beams, and a space frame is also used as the roof. How is the definition done? Thanks in advance
You can solve such a project only by assigning the appropriate moment of inertia and modulus of elasticity to the steel beams with the ideCAD Static version 7. We have heard that the steel program they are considering in the future will be suitable for designing completely independently designed steel structures.
Hello there; Whatever you call IdeÇelik or IdeStakik8, I think that the future version can be used together with steel and reinforced concrete elements in the same project, which is integrated with the current reinforced concrete version. That's how it should be. Because the IdeYapı family is always a few steps ahead of its competitors, thanks to its equipment that makes a difference. Best regards.
