steel factory design
Hello there; All in-truss connections have been selected as welded in your project, and weld+plate option will be more suitable for the sections you use. To connect the truss headers to the column header, you need to turn off the valve options in the additional properties tab in the truss settings. Apart from these two cases, there is no problem as data entry. Good work.
